can someone help me
Old Aug 30, 2019 | 04:45 PM
john73's Avatar
Default can someone help me
I have a volvo s60 2001 model. Am having issues with the Engine. When am driving up hill the car don't run more than 40km/h. And if i continue to press the accelerator the Engine start rough idling. which means that i cannot raise the rpm to more than 2000 rpm.
W
hat can be the cause if anyone has an experience with mind. And if stop to a red light, and want to drive again when it is green it runs very slow Before it gets its normal speed.
Old Aug 31, 2019 | 10:52 AM
Line-x_Guy's Avatar
Default Catalytic converter
Your catalytic converter could be stopped up.
Old Sep 1, 2019 | 10:34 AM
low power can be caused by a few different things - as noted you could have an air restriction (intake air? damaged exhaust pipe? clogged cat (any history of burning oil or loss of coolant?). Is the check engine light on? If so, have the car scanned for codes. Other causes could be low fuel pressure - clogged fuel filter, fuel pump issues, fuel pump relay, etc. Failed front oxygen sensor can cause power loss, as can a dirty MAF sensor, issues with the throttle body or intake air leaks (check for torn boots/hoses in the intake air path). You didn't mention engine model but turbo systems add a few more things to consider. Sounds like you need to take it in to your local shop for some diagnostic work.
rodizio1
Apr 12, 2016 06:21 AM
bybin
Sep 1, 2015 11:14 AM
Flow313
Jan 15, 2015 07:46 AM
Wesley brown
Sep 28, 2014 08:22 AM
photoman
Jun 9, 2005 09:07 PM
