car wont start...help
Hey guys i have my non turbo 740 sedan and it doesnt wan to start, can you help?
the problem is intermitten, it will start 75% of the time but the other 25% it just cranks and cranks. if i leave it sit for a day it'll fire right back up. I think that it is some kind of electrical issue Have any of you guys seen this before? I have replaced the coil (which did fix it once) and the fuel filter (routine maintenance) other than that it is a bone stocker with about 95,000 miles on it. Thanks for any help guys.
norbert
norbert
Hi Norbert,
Greetings from Yokohama, Japan.
As I'm an 850 driver, I'm not privy to 740. With my poor knowledge on 740, I can only assume the following:
1. Fuel pump is about to die.
2. Camshaft position sensor is about to die (if installed on 740).
3. The car may need good tune-up, mostly the ignition system (plug, plug wires, distributor cap & rotor, etc...) or fuel system.
4. Electronic control-related problems. Have the codes checked.
Also, post this question in the 740 forum; you'll receive better replies there. This is general topics area, and is dismal. So, try the 740 forum.
Good luck,
JPN
Good luck,
JPN
Fern Schmidt
2001-2013 model year V70
08-13-2013 06:43 PM
furball3
01-28-2007 03:31 AM
