check engine light
My gas cap was loose and I'm sure it caused my check engine light to come on. Is there an easy way to clear the code and get the light to go out? Does disconecting the battery for a time do it? Thanks for your help, Bill
I have the same problem. Periodically, it says that the fuel cap is loose and then goes away, leaving only the check engine light on. I went to the mechanic who checked it out and said that the sensor is bad and there may be a very small, harmless leak somewhere in the piping. He told me that it is not worth fixing and certainly safe to drive regardless of the check engine. However, this is not always the case.
ErnstlS90
Oct 23, 2008 08:37 AM
