Check Engine Light went off?
Old Mar 17, 2009 | 08:54 PM
Aimee's Avatar
Default Check Engine Light went off?
My check engine light on my '99 V70 had been on for about 7 months. Yes, I know that's bad, but my mechanic said it was a defective catalytic converter. As a broke college student living in a state with no regulated emission standards, I've had to ignore it until I can afford to fix it. Any thoughts on why it's suddenly turned off? I restarted my engine several times today, and it still hasn't come back on.
Old Mar 18, 2009 | 12:25 AM
BlazeS70's Avatar
The Check Engine light wlll reset if the battery is disconnected long enough.
Old Mar 18, 2009 | 07:01 AM
JPN's Avatar
JPN
If the CAT was bad, you would have noticed loss of power, rattling noise or rotten egg smell from the tail pipe (the 3 general symptoms of a failing CAT). However, the ECU (Electronic Control Unit: on-board computer that controls the engine, transmission, ABS, etc...) may have picked up out-of-spec signal from a sensor.
I would visit an auto parts shop such as Autozone and have them run the free diagnostic (called OBD-II: OBD stands for On-Board Diagnostic). They will hook up a hand-held scanner that can "talk to" the computer in your car and report if fault code has been set.
I hope this helps.
JPN
Old Mar 18, 2009 | 08:59 AM
Aimee's Avatar
Good idea, I'll take it to Autozone. Thanks!
Old Mar 18, 2009 | 07:26 PM
If the engine computer does not see the fault for a certain amount of drive cycles it will shut the light off but the code should still be present.
tngreg
Sep 5, 2022 07:27 PM
edgoss
Jan 1, 2009 09:33 AM
ErnstlS90
Oct 23, 2008 08:37 AM
f4x4tera
Jul 12, 2007 11:52 PM
gorogergo
Dec 1, 2005 11:23 AM
