Cummins Calterm + Metafiles
Old Apr 9, 2026 | 04:45 PM
aleksey-ms's Avatar
Arrow Cummins Calterm + Metafiles
Cummins Calterm 5.16
It's an engineering program for advanced tuning of Cummins engine ECUs. Unlike standard dealer scanners, it allows you to modify hidden factory calibrations: remove power and speed limits, and disable emissions control systems (EGR, DPF, SCR).
Why are metafiles (.ecfg / .ecf) needed?
These are configuration “translation maps” for a specific firmware version. Calterm will not work without them. They are needed for:
Navigation: they specify the exact address of the desired parameter in the ECU’s memory.
Decoding: converting raw machine code into human-readable text labels.
Conversion: translating numerical values into actual physical quantities (RPM, bar, degrees).
Conclusion:
without the correct metafile, Calterm simply won’t understand the ECU’s data structure and won’t allow you to read or change settings.
Need it? Push button Thanks, PM for pass | or by email right now.
chg1951
Volvo Recharge Models
Nov 7, 2022 08:36 PM
charlesbeb
Jun 23, 2022 06:16 AM
becnme
Penta
May 16, 2022 03:47 PM
SueW
Sep 15, 2020 03:39 AM
OurVolvo
Feb 10, 2018 06:21 PM
