Dead batt
Old May 10, 2011 | 01:21 PM
tceverett's Avatar
Default Dead batt
New battery replaced. After 10 days no juice. Had to recharge. No parasitic drain. Voltage reads 14.1 while running. Is this enough to keep batt charged?
Old May 10, 2011 | 10:03 PM
Yes, mine reads 13.7 while running.
Old May 12, 2011 | 11:23 PM
gdog's Avatar
How do you know there's no parasitci draw? Did you ck it?
Old May 24, 2011 | 11:32 PM
MattyXXL's Avatar
Originally Posted by rowanfredo123
Hey Buddy About Battery's Voltage There Available Many Equipment With Which You Can Found Your Batteries Status n Else .....
Ummmmm.... WHAT???
Old May 25, 2011 | 10:39 AM
donf's Avatar
My S70 used to do this. Took me awhile but here's what happened TO ME (maybe not you however). The trunk button on the fob is easy to hit and trigger, the trunk unlatches but doesn't pop up, if it's up just a hair the trunk light comes on killing the battery in a few days. Problem is, you can drive forever without realizing that the trunk is open and sometimes it is closed enoufg to not turn the light on. Lift your trunk lid. Turn off trunk light or remove the thing.
Old May 27, 2011 | 08:05 AM
S70_Driver's Avatar
Default Brake light switch
On my 98 S70, the brake light switch went at about 180,000. Apparently there is a spring in there that's supposed to keep it open unless you are depressing brake pedal. That can fatigue over time and switch can close on it's own.
The switch wasn't closed most of the time though, so this was a PITA to find. After a month of trouble, I finally found out because I came out at 2:00am to get something out of car one night by chance and saw my brake lights on.
jtab
Jan 30, 2013 09:42 AM
analogies
Jan 6, 2013 03:41 AM
artbar92706
May 26, 2012 07:02 PM
BigAdam
Aug 24, 2008 03:18 AM
the dit
Jun 17, 2007 10:19 AM
