engine dead, no spark 1989 760
Old Feb 15, 2009 | 03:18 PM
repairmantommy's Avatar
Talking engine dead, no spark 1989 760
first of all check & see if you have12 voltson your coil on firewall, if no spark,
you have one of four things going on :
bad coil
you either have a defective power stage ( ignition module ) bad which is over next to battery on fender well on left drivers side of car, or
you may have a coroded wire on relay which is on shock tower under hood on drivers side, theres two of them there together.
you could have wiring problem with crank position sensor, which is in distrubuter, not flywheel crank sensor, it don,t have one there. this sensor is in distributer, 3 wires come out of the bottom of dist, with plug, you could have electrical connection problem there under cap.
1 is for fuel pump
2 is for ignition
alpine
Aug 12, 2010 04:04 PM
BigAdam
Aug 24, 2008 03:18 AM
foster1
Jun 19, 2006 09:12 PM
foster1
Jun 18, 2006 04:20 PM
Paul1
Sep 10, 2005 01:57 PM
