flooding, rev problem 1989 760
Old Feb 15, 2009 | 03:30 PM
repairmantommy's Avatar
Talking flooding, rev problem 1989 760
does your car flood
does it act like it has rev limiter & misses
replace mass air flow sensor on air box
it is defective, also when doing this, this is a must
you must reset computer, by pressing button that is in dash, under the rubber plug in inst panel.
pull out plug, with switch off, press the button & hold while you turn switch on, then turn your switch off & release button
now you have reset, computer
be very careful when replacing the mass air sensor beacuse :
your turbo is going to run wild for about 5 minutes, be very careful & not bust you turbo hoses, you will be pushing 40 pounds of boost for 5 min
computer will readjust, you are now ready to run now, go to town, don't push it too hard for at least 30 minutes, let computer do its thing, then let it rip
vcolper
Apr 6, 2010 11:01 PM
sonja
Jan 22, 2009 04:36 PM
ckuttner
Dec 10, 2008 07:27 AM
jcmartin
Nov 13, 2007 02:09 AM
SuperDaddy
Mar 3, 2006 11:50 AM
