First Volvo: 5 sp wagon, 91 or 88?
Old Jul 18, 2011 | 11:22 PM
240 nut's Avatar
Default First Volvo: 5 sp wagon, 91 or 88?
Hello Volvo heads. I am about to buy my first Volvo EVER. I need a wagon. I WANT a five speed. I have a choice between a '91 with 270k that had an engine swap at 180 and an '88 -all original with 185k.
The 88 had more babying in its life, and while the paint finish overall is good but has a bit more rust. The '91 has an awful drivers seat- badly torn, heated control out - but otherwise seems fine inside. A bit beat on the exterior, though
The '91 needs rear control arm bushings, the 88 needs AT LEAST new front tires and poss. an alignment (shimmies over 55 mph). The '91 is in Beloit WI, the other in South Bend IN. I am in Chicago. The availability of 5 speed wagons is slim here and overall, prices are higher on used Volvos.
I have been researching and planning this purchase for a few months now, and of course the distance is not a large impediment, as the trips are 2 hours or less. Beloit is closer, though, enough to actually be a positive factor.
I will be bringing cash , whichever I go to see and test drive so if I am confident of the car I will not make a second trip. Any input on the year/s and posted issues?
91 Volvo 240 station wagon
1988 Volvo 240 DL Wagon
Old Jul 18, 2011 | 11:24 PM
240 nut's Avatar
Oh, the 91 is going for 1000 and just went up, the 88 for 850 and has been posted for weeks!
Old Jul 19, 2011 | 07:45 PM
fcpgroton's Avatar
Former Sponsor
My vote is with the 88.
Old Jul 20, 2011 | 10:52 AM
240 nut's Avatar
Default New wagon in the mix
First of all the "88 is $950, not 850, but still, why the '88? The newest option is a '94 940 for $1000. It only has 120k on the working odometer! Hearse black, cloth int. decent clearcoat finish. It is NOT a 5 sp. One good thing is that it is only 5 miles away, not 150 or more. Why so cheap? I don't known yet. The A/C is out, drivers seat heat malfunctioning (too hot). I do not like the design as well on the '94, but as far as I can tell, the engineering is still solid.
Old Jul 20, 2011 | 09:51 PM
240 nut's Avatar
So, the '94 940 priced at a grand went without me getting even a test drive. My wife wold have liked that one more with the auto trans and slightly smaller size, Oh well, she has her '05 Matrix, which she loves. The shiny black 940 looked like a Herse anyway... So back to the remaining two 5 speeds. Andrew, are the '88s easier to work on than the '91s? is it the original engine and lower miles that would incline you to recommend the '88?
Old Jul 20, 2011 | 10:15 PM
240 nut's Avatar
VOLVO WAGON 1988 74O GL...*4 CYL. 〉*5 SPD. STICK - $1695
VOLVO WAGON 1988 74O GL ...206K...
*5 SPEED MANUAL SHIFT
*4 CYLINDER (2.3 LITER) GAS SAVER
NEW TIRES & TUNE UP OIL/FILTER
NEW FRONT &REAR.BRAKES
NEW SHOCKS (STRUTS)
NEW BALL JOINTS & SWAY BARS
NEW COMPLETE EXHAUST
NEW REAR MAIN SEAL
NEW MOTOR MOUNTS
NEW WATER.PUMP-
NEW.TIMING BELT PLUS SERPENTINE BELTS
NEW.COMPLETE CLUTCH KIT
******PREV.OWNED BY A VOLVO MECHANIC @...
Just found this, a bit further away and a little past my price range. Would I
be foolish to pass this one up?
xszydx
Aug 18, 2012 06:26 PM
djforresta
Jul 4, 2010 11:15 PM
volvomang
Aug 23, 2009 02:13 AM
glkprhog
Jul 4, 2007 02:39 PM
USSEnterprise
Sep 30, 2006 05:49 PM
