Framework costs?
Old Feb 13, 2006 | 07:52 PM
Blozend's Avatar
Default Framework costs?
recently i ran into a curb at about 35 mph. i had hoped that my tire just needed to be realigned but the mechanic told me it was more serious. the mechanice could not help me because the frame is bent. the lower half of the tire shifted inward about 1.5inches and is not aimed straight. i need to get to a shop that works on frames. Im just wondering if there are any estimates as so how much this will cost me...
Old Feb 13, 2006 | 09:29 PM
Default RE: Framework costs?
A little more info would help a little more.
Is it a front tire?
Is just the subframe bent?
Is just the lower control arm bent?
Old Feb 13, 2006 | 10:38 PM
Blozend's Avatar
the mechanic only said the frame was bent. and it's the driver's front tire
Old Feb 13, 2006 | 11:05 PM
The subframe can be replaced. Not to sure of the cost though. The Dealer or Some one with an engine support can do it.
Old Feb 14, 2006 | 10:12 AM
JimKW's Avatar
Check with you insurance if the cost is more than your deductable. If it's covered under comprehensive it will not imact you rate. I think you probably hit a pot hole though not a curb.
Colinruss
Dec 12, 2007 05:10 PM
afton
Oct 24, 2007 04:29 PM
uncle
Sep 24, 2006 09:54 PM
hoop
Sep 6, 2006 10:49 PM
ThePassingOfAmerica
Apr 21, 2005 03:17 PM
