Gas leakage from my 1999. Volvo s80
Old May 31, 2023 | 05:11 AM
Rainers201's Avatar
Default Gas leakage from my 1999. Volvo s80
Hello, I have 1999 Volvo s80 i recently changed engine, Replacement was the same exact one.. once I tried to start it it started leaking gas from the 3-way hose connector witch connects to fuel pump, fuel filter and main fuel rail to engine. I replaced the whole thing and then tried to start it, it was the exact same leakage as before, so I started to think maybe there was some blockage or the pressure doesn’t drop, so I replaced fuel pressure regulator, fuel injectors, and even blew out engine fuel line in case there was the blockage, but none of that worked. I don’t know what to do next. Upon the old 3-way fuel line inspection I saw nothing wrong with it and no hose was blown off. Fuel doesn’t leak when you turn the ignition on, it only starts when I try to start the engine.
Old May 31, 2023 | 09:06 AM
did you accidentally reverse the return line with the feed line?
BCFischer
1998-2000 model year V70
Feb 21, 2019 03:52 PM
Lab_Rodent
Jun 16, 2017 04:29 AM
cdxnolan
Feb 14, 2016 02:39 AM
jayson44
Apr 24, 2013 08:03 PM
raygnlz
Jan 16, 2010 12:00 AM
