Hard Cold Start 2004 v40
Old 06-17-2018, 10:06 PM
jgermano's Avatar
Default Hard Cold Start 2004 v40
I am baffled by a cold starting problem. The car is hard to start in the morning but a ok the rest of the day. Here is what has been done so far. The fuel pump has been replaced, the fuel pressure regulator has been replaced, the coolant temperature sensor and thermostat, as well as the idle air control valve has been replaced, I have taken it to three mechanics and they can't figure it out. I have cleaned the MAF sensor but have not replaced it. Where should I look next?
Old 06-18-2018, 09:16 AM
have you measured fuel pressure? any puff of black smoke when you do your first cold start? I'd suspect either an intake air leak, the MAF or perhaps a leaky injector which is lowering pressure at the rail.
Old 06-19-2018, 08:17 AM
jgermano's Avatar
I have not. I will check it and get back to you. Thanks for the reply!
jgermano
09-05-2019 06:06 PM
Smdrew
09-01-2019 10:27 AM
George4
09-17-2016 04:34 AM
davesee1
01-31-2011 07:20 AM
Armysf
02-05-2010 08:30 AM
Quick Reply: Hard Cold Start 2004 v40
