head gasket change on 1995 960 2.5l engine
Old Apr 3, 2013 | 01:39 AM
Xazar's Avatar
Default head gasket change on 1995 960 2.5l engine
can anyone give mer advice ?..i got 1995 volvo 960 2.5l engine..i need to replace head gasket.how to remove intake manifold clamps?..they are crimped...do i need to replace them too...does it need special tool to install..has anyone come cross with that?..is it possible to remove intake manifold{to avoid damaging clamps} with the head?..how to proceed?...thanks guys
Old May 5, 2013 | 08:55 PM
Tjmphx's Avatar
I shaved down a flat head screw driver to make it thin enough to slide into the crimp. If you look closely at the clamps one side will pop open with a slight twist. Only unclamp the side towards the block. If your gental enough the clamps will be reusable by squeezing them back together with flat tip pliers.
boxpin
Dec 20, 2015 05:08 AM
Reid
Feb 13, 2011 10:01 PM
eallanboggs
Oct 21, 2008 09:29 PM
ENDEE666
Nov 8, 2006 08:29 PM
johnnybravo
Engine & Internal
Apr 5, 2006 12:52 AM
