jack points for 1998 v70 to get out gas tank
Old Apr 22, 2013 | 12:21 AM
nachobear's Avatar
Question jack points for 1998 v70 to get out gas tank
Does anyone know where to put the jack stands and where to jack the rear of the car with a floor jack? I need to take out the gas tank so I assume I need to jack up the car. The chilton car manual book says
Place jack stands beneath the rear end of the subframe to support the front of the vehicle
also it says
Paise the rear by jacking at the REAR SPRING PERCH, then place the jack stand under the frame rail; raise only one side at a time
Please give me pictures or a video because this handbook is in black and white
also there is a clamp or something with 2 bolts that is holding the the gas tank to the gas hose, if I remove the clamp is there anything else to remove
In the volvo manual it also says
If a garage jack is used to lift the car, the two jack attachment points should be used. - I'm guessing its talking about the center jacking point of the car
A garage jack can also be placed under the reinforced plate in the spare wheel well. - Does this mean I can jack under the section of the car where the spare tire is kept?
If a two-post hoist is ised to lift the car, the front and rear lift arm pads should be centered under the reinforced lift plates on the inboard edge of the sill rail. The position of these plates is marked with arrows molded into the bottom of the sill rail. - guessing I don't need to know this since it doesn't talk about a floor jack
Last edited by nachobear; Apr 22, 2013 at 03:00 AM. Reason: adding more information
Old Apr 22, 2013 | 05:46 AM
Do you have ramps? If possible just drive the car up on them unless you have to pull a wheel.
I usually put the jack stands under the frame close to the wheel suspension. As for jacking it, I always jack it at the side jacking point.
Old Apr 22, 2013 | 11:32 PM
nachobear's Avatar
Question
Hi
The car was in an accident so it can't move and also do you mean jacking in in the center where the scissor jack is used or are you talking about the points where there are arrows under the car, how can you tell which part is the frame
Old May 3, 2013 | 02:47 AM
Sir Vivor's Avatar
As it turns out, this is the very question I set out to answer this time round here. Just bought a pair of lovely jack stands, and it would be splendid to be able to employ them without smashing through the floor.
My v70 is a 2001.
Sorry, I don’t understand technical terms like:
subframe
rear spring perch
sill rail
side jacking joint
Anyone who has achieved expertise in their field can bewilder others with proprietary jargon. Can anyone here translate into English?
Old May 5, 2013 | 12:03 AM
nachobear's Avatar
My v70 is a 2001.
subframe
rear spring perch
sill rail
side jacking joint
wish i can help you and give u an answer i dislike this suggestion but take it to autozone,pepboys or a volvo dealer thats your best bet
or you can try to ask these other sites
matthewsvolvosite.com/
volvospeed.com
volvoforums.org.uk
volvoforums.com
sorry wish i can tell you i wish u the best
RedTurbo850
Jul 17, 2012 04:57 PM
bw77
Apr 22, 2009 08:28 PM
brianet
Aug 9, 2008 07:32 PM
gquodala
Aug 1, 2008 02:42 PM
CVOLVO.COM
Volvo C30
Oct 1, 2007 09:00 PM
