Left rear of car 1 inch higher than right
Old Dec 2, 2009 | 06:04 AM
cb1313's Avatar
Default Left rear of car 1 inch higher than right
When I measure the rear wheel arch the left side is higher than the right....anyone else ? How did you fix this ?
Cb
Old Dec 3, 2009 | 04:58 AM
Typhoon's Avatar
If it's an inch or less, perfectly normal for suspension to settle that way, engine torque does it over time. I've owned several V8 cars that have been that way. They've actually had up to two inches of stagger when they were really old.
If you don't believe engine torque can do this to springs, go find an old dump truck or concrete truck, they get massive leans as they get older.
If it's an inch or more, poke your head under the low side and look for a broken spring. It will be obvious with a torch.
It could also be a stuck shock, but they are pretty noticeable when driving, the car tends to lurch around the stuck shock. Way to test for a stuck shock is to merely jump up and down on rear bumper. If one side is stuck, it won't move much.
Regards, Andrew.
Old Dec 3, 2009 | 05:58 AM
cb1313's Avatar
Typhoon, thank you for the reply. The shocks are brand new and everythings looked good When I checked. I did the rear shocks myself.
I have a question about your user name.... Do/did you own a GMC Typhoon ? I only ask because I've had one for 16 years now.
Cb
Old Dec 3, 2009 | 01:15 PM
Lyonsroar's Avatar
Pics of Typhoons!!
One of my favorite cars of all time!!
Old Dec 3, 2009 | 02:34 PM
cb1313's Avatar
Default Typhoon picture REQUESTED
I can't beleive that I have had this car for 16 years and only have 2 photos .... I also have no photos of my other stuff.
Sorry... I do not know how to load photos in my threads ..?? Help ?
Cb
Old Dec 4, 2009 | 02:03 AM
Typhoon's Avatar
Nah, I was into Typhoon before the car came out, and by the way, the Typhoon was never released here in Australia ( actually, GMC has never imported vehicles down here).
I was once a big fan of the Hawker Typhoon aircraft, and the username has stuck!
Regards, Andrew.
Old Dec 4, 2009 | 11:17 AM
Lyonsroar's Avatar
Cb
Alright. What you're gonna do is make an account here: http://photobucket.com/
and click the button that says "upload images and videos"
Find the ones you want, click upload
After they are done uploading, they will be in your gallery. Click one.
On the left hand side of the screen there will be a box called "share this image"
You're going to copy the "IMG code" and paste it into your forum post.
It's pretty self explanatory once you get in.
ENDEE666
Oct 12, 2012 08:51 PM
Nirky
Aug 30, 2011 08:27 AM
cb1313
Jun 24, 2009 07:14 PM
TLC_Lover
Aug 27, 2007 01:59 AM
