'90 740GL AT won't go higher than 2nd gear
Old Aug 29, 2011 | 06:37 PM
Nirky's Avatar
Default '90 740GL AT won't go higher than 2nd gear
Last week the car had trouble going into overdrive. This week it will only go into 2nd gear. Transmission fluid level & color unchanged. 180k mileage. Is my tranny going south, or are there some things I can do to possibly help....I dunno, fluid change, flush, special treatment?
Old Aug 30, 2011 | 08:27 AM
act1292's Avatar
Is the transmission fluid nice & pink? Does it smell burnt at all?
Certainly a flush wouldn't hurt. If the fluid is brown and smells burnt, then your transmission is toast. If not, the flush may help. Another thing you might want to check is the linkage bushings. Is your shift lever really sloppy? If so, perhaps it is in 2nd instead of Drive.
Good luck
ENDEE666
Oct 12, 2012 08:51 PM
cb1313
Dec 4, 2009 11:17 AM
cb1313
Jun 24, 2009 07:14 PM
netscarf
Apr 4, 2009 09:47 PM
TLC_Lover
Aug 27, 2007 01:59 AM
