Low electrical buzzing noise '06 XC90
Old Jul 14, 2010 | 09:37 AM
jsabuda's Avatar
Default Low electrical buzzing noise '06 XC90
Hello,
When power is off, I hear a very low electrical buzzing noise from behind the
lower section of the climate control/CD player panel.
I noticed the noise after having the AC unit replaced and this noise seems to be constant. ie: after being in my garage all night, the buzzing was still humming away in the morning, before turning the vehicle on.
Any ideas as to the cause of the buzzing are welcome.
Best Regards.
Jeff
'06 XC90 Turbo, 49kmi
Silver
Old Jul 17, 2010 | 07:49 PM
Pull the fuse on the cd player and see if it stops. Make sure you have any security codes or what ever you will need to get it back on. I would start pulling fuses 1 at a time until I find the problem.
Old Jul 22, 2010 | 08:29 PM
ibanez958's Avatar
the noise is most probably from the passenger temp. sensor which is inside the ccm. usually if there is a ccm code, the ccm will still run for a while even after the engine shut off. the best way to diagnosis is to hook up vida to see if any dtc's first.
ashvolvo
Apr 26, 2011 01:13 PM
timmylittle
Dec 30, 2010 02:23 PM
postjosh
Aug 2, 2010 07:38 PM
dj296
Sep 16, 2006 08:03 PM
jessekinsman
Apr 26, 2006 09:40 PM
