Is my new Brembo rear rotor defective? (1992 245 DL)
Old Jun 27, 2009 | 10:25 AM
ds1455's Avatar
Default Is my new Brembo rear rotor defective? (1992 245 DL)
I was changing out my rear pads and rotors today and noticed an irregularitiy on on one of the Brembo rotors.
One of the rotors has two 4 or 5 millimeter diameter recesses about 1 or 2 millimeters deep on the outside disc surface. They are about 180 degrees apart.
I bought them from Groton so I can't help but think they looked them over but....
Thanks in advance.
Old Jun 27, 2009 | 10:27 AM
Somthngfrce's Avatar
how old are they and how long have they been on the car........I would email them and its a manufacturers defect, then they should be able to help you. Now if they have been on the car a while, then that might be a tough situation.
Old Jun 27, 2009 | 10:30 AM
ds1455's Avatar
It is brand new!
Old Jun 27, 2009 | 10:32 AM
If it is just like a circle in the middle of the rotor that is normal it is a wear indicator.
When the circle is gone the rotors are below Min. spec and need to be replaced.
Old Jun 27, 2009 | 11:00 AM
ds1455's Avatar
Default But.....
That's great but didn't the other have it and the 2 front rotors I changed months ago didn't?
Thanks you!
Old Jun 27, 2009 | 11:03 AM
It is a newer thing you might have gotten older stock on the other ones.
It kind of looks like someone took a drill bit and drilled a hole shallow right?
If so then yes it is normal.
Old Jun 27, 2009 | 11:11 AM
ds1455's Avatar
Default Yes
It looks like a drill bit but the hole bottom is faltish and the depth is only .6 MM
Old Jun 27, 2009 | 12:23 PM
ds1455's Avatar
Default Thanks!
I put the rotor on. Thanks again!
Old Jun 27, 2009 | 06:30 PM
Yes that is normal.
Old Jun 29, 2009 | 09:27 AM
fcpgroton's Avatar
Former Sponsor
I just came across this thread.
Cosmetically this is normal. I'm sure the rotor will perform just as well.
greenman86
Nov 8, 2014 07:27 AM
ds1455
Jul 2, 2009 09:13 AM
cudavid
Jan 3, 2008 09:04 PM
foreste2002
Nov 13, 2006 02:31 AM
Cornfed
Apr 14, 2006 11:36 PM
