my v70 issues
my v70 issues
hi there i currently own a 2000 v70 with a couple of problems was looking for any ideas the first problem is in the morning when i drive just over one mile or so when i brake the pedal goes hard as if i have no brakes i let off and brake again and brakes are perfect all day am ataloss what this could be any ideas would be appreciated thanks
Not sure but maybe you should post this in the V70 section and search that area. Brake systems have fluid, master cylinder, and calipers. Have the brakes been blead lately? Has fluid been replace within the past 2 years? Is there ample fluid in the res? Service the brake fluid system and see what happens.
Last time I had this happen on my Sentra was because the caliper guide pins were not lubed properly. WHat happens is the first time you press on the brake it feels like nothing since all that force is being applied against the friction of the dirty guide pins. Then once you squeeze past that, it works fine. When replacing brake pads, the caliper guide pins should always be cleaned (brake fluid works nicely) and relubed with special grease.
Hannahlyn13
06-03-2011 12:23 PM
