new axle install
Old Sep 16, 2007 | 04:03 PM
buzzforb's Avatar
Default new axle install
i appear to be in the eye of the storm, so to speak. [>:]any tips on how to get drivers side axle pushed in all the way. I can't seem to get the c-clip to compress so that the axle will pop in. I drive a 95' 850 wagon.
Old Sep 16, 2007 | 05:55 PM
JPN's Avatar
JPN
Default RE: new axle install
Hi,
Do you mean the outer (wheel side) CV-joint side's Circlip? It would be much easier to install than to remove one. My fellow mechanic in Vermont has a special pair of pliers that is specifically used on those Circlips.
Try tapping with plastic mallet to see if the Circlip clicks in place.
Or, wait until the top-dog of the forum named Moderator Tech replies.
Cheers,
JPN
Old Sep 16, 2007 | 08:30 PM
TheSteelKnight's Avatar
pst.....pst...tech, thats your que. watch this, its gonna be cool .
Old Sep 16, 2007 | 09:02 PM
If the clip looks to stretched replace it.
If it doesn't look to bad make sure the axle is going in straight then hold the outer part of the axle and slide the inner part out some then slam it in. It is almost like using a slide hammer to install it.
Then if all else fails try to locate an old Axle nut and install it till the nut is about flush with the end of the threads thenus a big hammer to tap it in.
Old Sep 17, 2007 | 08:35 AM
buzzforb's Avatar
Thnks for the help. Everyone has been a huge help.
bigboy
Jul 1, 2015 10:54 PM
Ewee
2001-2013 model year V70
Feb 5, 2013 09:28 AM
ctullar
Nov 20, 2010 04:27 PM
rangerjoe0202
Oct 28, 2009 01:28 PM
ludeless
Jan 18, 2006 01:01 AM
