OBD jumper wire repair
Old Feb 20, 2018 | 01:57 PM
eric d.'s Avatar
Question OBD jumper wire repair
Hello,
I have a 1995 850 turbo and the jumper wire has broken off inside of the module. Has anyone opened one of these up before to repair this? Just curious so i don't make matters worse.
Thanks in advance for any direction on this.
Old Feb 20, 2018 | 06:43 PM
I had a similar problem and simply used a paper clip to connect the probe to the module whenever I need to read out. There's also a way to make your own LED reader/push button connecting to the interior port (unfortunately I haven't saved the link). As a plan b you may want to see if any recycle yards or people parting out an 850 can pull the module from a donor.
Old Feb 20, 2018 | 10:12 PM
firebirdparts's Avatar
I think that is just a wire to ground.Check me on that, though.
Old Feb 21, 2018 | 05:54 PM
eric d.'s Avatar
Thanks for the advice. The paper clip seems like it will work, however since I wrote this I have found an OBD II port under the coin holder by my shifter. Maybe I can get a scanner and do everything I need from there. Who knew the car had both. Thanks again for the advice.
georgev70
Aug 4, 2011 08:59 PM
CactusTaxi
Sep 2, 2010 09:30 PM
anotherskait@yahoo.com
Aug 28, 2010 01:37 PM
malaka
Mar 8, 2010 05:58 PM
Dads850
Mar 5, 2009 03:18 PM
