power lock doesnt lock
Old Sep 19, 2006 | 04:50 PM
cganotisi's Avatar
Default power lock doesnt lock
02 s60--- when i press the lock button on the remote, all the doors lock except the front passenger door. The door lock "peg" goes down and pops back up. Its weird because sometimes it takes about 3-5 presses before it stays locked... and sometimes it stays down on the first try.
I went thru the owners manual to see if this was normal, but there were no mentions of it.
What i need to know is if this is normal or if this needs to be brought into the dealer for repairs (i'm still under warranty).
thanks...
Old Sep 19, 2006 | 08:59 PM
Default RE: power lock doesnt lock
Door lock assembly is bad.
Old Sep 20, 2006 | 02:38 AM
cganotisi's Avatar
thought so...
think the dealership would give me a hardtime with the repair?
Old Sep 20, 2006 | 08:31 PM
They shouldn't give a problem make sure you show someone what it is doing.
Old Sep 22, 2006 | 12:47 AM
cganotisi's Avatar
why is it that only when the remote is used to lock the doors, it happens... but if i lock the doors by inserting the key into the drivers side, theres no prob?
Old Sep 22, 2006 | 01:20 AM
I believe it is when you use the key you get the parts moved all the way to hold the Microswitch down.
When you use the remote it depends on the lock motor to do it.
crgolf
Feb 10, 2013 12:43 PM
jeeta
Apr 22, 2011 08:25 AM
pconfar
Jun 11, 2010 02:10 PM
SKRIBZZRC
Nov 17, 2009 02:58 PM
vic420413
Dec 12, 2006 08:38 PM
