rear right fog lamp not working
Old Jul 7, 2010 | 09:39 AM
shako's Avatar
Default rear right fog lamp not working
I have a 2007 Volvo XC-90. I turned on the rear fog lamps (red in color) and the right rear did not work. I removed the cover to notice that it did not have wiring or a bulb in the light. Is this common? Do I have a defective light? Any answers?
Old Jul 22, 2010 | 10:30 AM
GreeseMunkee's Avatar
Same on my 960. However on mine there is a socket for a bulb. So, I'm going to cut the hole, toss a bulb in, and see what happens
Old Jul 22, 2010 | 06:55 PM
They were made to only have 1 light to help people see you in fog, heavy rain or snow (it's how it is designed). If you somehow get 2 to work, it will look like you have your brakes on. One will do the trick.
Old Jul 23, 2010 | 08:10 AM
If 2 brighter tail lights would lead someone to believe you're on your brakes, then one brighter tail light would lead them to believe you have a brake light out. If you're driving in conditions requiring rear fog lights, the illusion that you are on your breaks should work in your favor by causing drivers behind you to slow down sooner.
Old Jul 23, 2010 | 06:35 PM
ibanez958's Avatar
no, your car is performed as per designed. on the 07 XC90 only the the left rear bumper light is on when the rear fog light is on.
idiotjoketeen
2001-2013 model year XC70
Aug 12, 2015 06:21 PM
commoncold
Jul 22, 2014 05:41 PM
AA752
Mar 22, 2014 02:58 PM
35mm
Apr 22, 2012 01:36 PM
