Removing couplings from fuel pump 95 [850]
Old May 18, 2009 | 10:19 AM
timskaku's Avatar
Question Removing couplings from fuel pump 95 [850]
hello,
does anyone have a method of removing the "quick release" couplings at the fuel pump on a 1995 850 turbo (2.3l).
i have hunted the internet for the volvo tool [999 5533]. It is the same tool used to remove the fuel inj. Couplings [i think]. Any ideas would be welcomed, as i don't want to ruin the coupling. A fifteen minute job of replacing the pump motor has turned into a week of searching, and phone calls to dealers, who were not very helpful!
thanks for any advise or methods!
timskaku
vashon is. Wa.
Old Jun 7, 2009 | 11:51 PM
djc126's Avatar
Default RE: changing Fuel pump procedure
Hi. I too need to change my fuel pump to diagnose a starting problem.
From what I've read on Brickboard - you can make due with a flatblade screwdriver and gently pry the lines off. Or you could try an interior panel trim remover - V-shaped end is bent 30 degrees.
Let me know how it goes.
Old Jun 8, 2009 | 05:01 AM
I use 90 degree needle nose pliers.
clt750
Aug 3, 2013 10:23 AM
spidersilva
Aug 17, 2011 07:23 PM
GPVolvo
Oct 26, 2010 07:50 PM
annmar65
Mar 24, 2009 02:00 PM
