Repairing Side View Mirror
Old Nov 24, 2010 | 01:40 PM
Ckarczmar's Avatar
Default Repairing Side View Mirror
The glass is cracked on the Passenger Side View Mirror (2001 V70-Turbo Station Wagon). I was told I could replace just the glass, instead of the entire unit - the housing is not damaged. Does anyone know how to do this? Can I do it myself or should I have mechanic do it?
Thanks,
ck
Old Nov 24, 2010 | 08:24 PM
cooness's Avatar
had the same problem with the drivers side on my xc90. the dealer did it very quickly. i think it was a half hour labor. you can try it your self, you have to hook it on some how. good luck.
Old Nov 25, 2010 | 07:46 AM
ibanez958's Avatar
u could do it yourself, but u could also crack the new one if u try to force it in
Old Nov 25, 2010 | 01:31 PM
I think he is looking for instructions. If you can find one in the yard it will be easy. Inside of the door has a little panel that you pull off, at least on the S90's. Then there are two screws and a wire connection. You may have to pull the door panel loose to get at the electrical connection.
Old Nov 25, 2010 | 08:44 PM
Ckarczmar's Avatar
Smile Volvo V70 side view mirror
Thanks folks for the replies. To my surprise, I was able to do it quite simply - purchased the mirror without the full housing for $ 50. Simply unhooked the two cables from the old, broken one, attached them to new one and basically just snapped it into the housing. I must admit to being slightly shocked when the automatic adjustment actually worked!!!
Old Dec 17, 2010 | 12:37 PM
njcardsfan's Avatar
Where did you get the mirror? I need one for a 2000 XC70. Thanks.
beba
Dec 15, 2016 08:33 PM
creekbat
Sep 28, 2016 11:43 AM
Richard74
Dec 11, 2006 09:13 PM
Peteflies
Sep 24, 2006 11:29 AM
karl53201
Dec 21, 2005 12:46 AM
