S40 questions, new owner....
Old Apr 27, 2006 | 12:42 AM
dark's Avatar
Default S40 questions, new owner....
I had my first drive today in my 2002 S40.
impressive acceleration, brakes.....many more.
a few questions.
1. are breaks supposed to be noisy right before u stop, like a to much steel on steel noise?maybe i dit not word it right...the fraction of the second you stop, makes a squeak...
2. what is the W button on the tranny and when do i use it?
3. what is the shift button on the tranny and do i have to use it? i had to press it.....
4. what is the normal idling rpm for this car? (1.9T)
5. are aftermarket stereos compatible with volvo audio system?
thx
Old Apr 27, 2006 | 01:34 AM
Default RE: S40 questions, new owner....
1. The car might have aftermarket pads on it which are known to squeel. No it is not supposed to do that.
2.The winter button is used when driving in Snow. The car starts off in 3rd gear for more traction.
3.The button is a shiftlock overide. So if you ever step on the brake and it won't come out of park Hold the button down to get it out of park.
4.The normal idle for the car is about 750 RPM
5.Yes aftermarket radios are compatible.
Old Apr 27, 2006 | 11:05 PM
dark's Avatar
thx for the insight.
this morning i had some problems while starting up the car: i actually had to push the gas pedal a few time to give it some boost while the key was turned on in the ignition, otherwise it wouldnt start. No warning or engine lights, no nothing, it just wouldnt start. Once started, i think it is not performing at 100%..this is only a hunch since it is my first volvo ever. i was thining about a tune up.
How often do I have to change the tranny fluid? i dunno if has even been done, i am 98500 km right now.
And 1 more question..while in park, it idles at 2 lines and a half under 1000 line, whatever that is. It sounds like a diesel engine to me, like a ratatatataatatatatatatatatataatata.....
how loud are they supposed to be?
some of the questions might seem stupid, please bare with me here, i am just a noob that has found a real car.......
thx for your time...
Old Apr 27, 2006 | 11:41 PM
The trans fluid I would do at about 100,000 miles or when it looks BROWN instead of red.
The noise you hear might be the engine mounts collapesed.
Old Apr 28, 2006 | 08:45 AM
dark's Avatar
wow, that sounds kinda expensive.
is there a way i can check them?(engine mounts)
Old Apr 29, 2006 | 01:10 AM
The one by the top of the engine on the right side. Look at the back side of it you should see a plastic peice by where the bolt goes through the middle of the mount. See if the plastic is touching the rubber on the top.
If it is then it is bad.
The lower ones look at and see if they are cracked or touching the sides. Once you look at them you should see what I am talking about.
Phil 850
Jul 25, 2012 10:01 PM
Madysdad
Aug 23, 2010 10:46 PM
boosted AWD
Feb 19, 2009 02:12 PM
Tupolev22m
Sep 12, 2006 02:27 AM
VVMommy
Oct 11, 2005 11:03 AM
