S80 D5 SE 2003 - Noise when turning
Old Jul 26, 2013 | 03:06 AM
James88888888's Avatar
Default S80 D5 SE 2003 - Noise when turning
I have bought a 2003 S80, D5, SE, 62K on the clock, full history, 1 owner.
There is a grinding nice when turning the wheel left or right.
Have checked the suspension arms, PS fluids etc.
Have read that this could be an inherent fault, is this true?
I look forward to some help.
Thanks,
James
Old Aug 2, 2013 | 08:43 AM
am12eaz's Avatar
There are normally a bush either side which stop the wheel touching the inner arch which is probably the noise have you checked the inside of the arch for tyre rub. Check for the bushes on the bottom arm to see what it's touching this is the arm or bar that hangs off the cv joint. It should be against rubber
Livens
Sep 13, 2017 12:56 PM
angryboys604
Mar 14, 2014 03:45 PM
bg851
May 21, 2009 07:24 PM
miguelalanis
Engine & Internal
May 5, 2008 07:20 AM
rp850
Jul 27, 2005 12:45 AM
