scanner diagnosis
Old Oct 29, 2010 | 08:40 PM
amythuytran's Avatar
Default scanner diagnosis
My volvo s60 was scanned and it show:
P0497 - EVAP emission low purge flow fault
P0190 - Fuel rail pressure sensor circuit malfunction
P0193 - Fuel rail pressure sensor circuit high input
What does all that mean?
Old Nov 3, 2010 | 06:27 AM
hal0691's Avatar
Default s40 cutting out
my 2002 s40 has been cutting out, when the car is slowing down , when the brake pedal is pressed or when moving from 5th to 4th gear, any ideas
hal0691
Old Nov 3, 2010 | 06:35 AM
Should both of these post be ignored???
amythuytran: You may want to post your problem in the S60 section. Also include what is going on with the car, if the codes were reset, what year and make your S60 is. Is the car running rough or just seen a CEL?
hal0691, Same to you about the model specific section. Sounds like some kind of idle control problem. However 5th to 4th should not be a problem. Does your car have a 5 speed auto transmission?
Volvo2001
Oct 24, 2006 10:12 PM
skipper
Oct 3, 2006 10:24 PM
axelm
Feb 27, 2006 09:06 AM
tomservo
Dec 25, 2005 03:01 AM
JimKW
Aug 4, 2005 12:07 AM
