starting/stuturing problem
Old Sep 9, 2008 | 07:48 PM
georgep's Avatar
Default starting/stuturing problem
[align=left]2000 s70 2.4t 104k miles hard starting revs up slowly settles down then when gets to normal temp stuters when in gear/ac on. check engine lite on says turbo reg switch- changed out as well as vac hoses. no change. thoughts?
[/align]
Old Sep 9, 2008 | 08:02 PM
Default RE: starting/stuturing problem
What was the exact code that was in there?
Old Sep 9, 2008 | 08:19 PM
georgep's Avatar
the code said turbo super boost regulator this was done at a local repair shop
Old Sep 9, 2008 | 08:45 PM
If it is that then one of the lines for the turbo system is broke.
That is one of the small vacuum lines going to the turbo.
watchdog
Feb 9, 2014 01:41 PM
TedP
Feb 12, 2007 01:31 PM
br549
Sep 28, 2004 09:15 PM
watchdog
Jan 23, 2004 11:36 AM
