Triler Hitch Receiver Adapter for 2020 XC60
Old Feb 27, 2020 | 09:25 AM
daveR1979's Avatar
Default Triler Hitch Receiver Adapter for 2020 XC60
I have a new XC 60 that I got a trailer hitch installed from Volvo to use my Thule bike rack with. I discovered that the receiver on the car is 1.25" and the standard Thule rack is 2". I bought an adapter for the conversion of 1.25 to 2 and the Volvo receiver does not allow adapter to go in far enough to line up pin hole to lock hitch in. Anybody had similar issue or solution? Thanks
Old Feb 27, 2020 | 12:15 PM
check out etrailer.com (I've used them in the past) they offer a range of hitch adaptors and have good content and good support for questions. Sounds like you just need to find an adaptor that matches your need. Otherwise you can probably drill a new hole to lock the pin in - its not like your towing a 3000 lb trailer - you just want to lock in the bike rack with the adapter on right?
Old Jul 10, 2020 | 03:57 PM
bcl1018's Avatar
were you able to find an adapter that works? i have the same problem. tried two different adapters and both did allow the apdapter to go in far enough.
Old Jul 12, 2020 | 08:37 PM
Cuso's Avatar
If you don't want to purchase the adapter or simply want a cleaner look, you can replace the hitch receiver with an after market class III or 2" for around $150.
Old Aug 4, 2022 | 01:11 PM
nextlostj's Avatar
Any luck finding a fit here? Tried 5 different adapters none of them fit.
Old Aug 4, 2022 | 01:13 PM
bcl1018's Avatar
i ended up sawing the adapter down so that it fit and locked in. been working fine since.
RVAXC60
Nov 3, 2017 06:42 PM
razorbackfan
Mar 5, 2016 07:37 AM
billobrien692
May 1, 2015 05:04 AM
carlxc
Feb 28, 2014 10:36 PM
Scott W
Jul 3, 2009 10:51 AM
