Typical V50/S40 Evap Drain/Roof Drain problem, with a twist
Old Jun 12, 2013 | 11:46 AM
jbarnes's Avatar
Default Typical V50/S40 Evap Drain/Roof Drain problem, with a twist
Hello all,
I have a 2007 V50 T5 and recently had the typical problem with water pooling in the rear passenger floor. I figured it was either the AC evaporator drain hose/plug or the sunroof drains. I took all the carpet and foam out of that side and got all of the water out of the bottom (gallons). I cleared the sunroof drains and they appear to be working well after testing. I've tried clearing the evaporator hose and plug - as far as i can tell it is clear. But i've noticed when my AC is running now, there is still some water dripping from somewhere slightly further forward than the hose. Do I have an bigger issue here, or is this just excess water that has built up in the AC box that will slowly drain out through the hose?
Any Suggestions
hovonogila
May 16, 2019 02:28 AM
SmrkngRvng
Feb 26, 2013 03:57 PM
bdr1
Oct 4, 2008 08:06 AM
rationull
Jun 11, 2008 11:27 PM
jnduke
Apr 11, 2008 08:20 AM
