Universal Cats???/
Old Aug 31, 2011 | 01:59 PM
c.carter's Avatar
Default Universal Cats???/
have a 2004 S60 that needs a new cat. engine light on did not pass inspection. Was told that a universal cat could be used. Then hear that for the Volvo the universal can not be used..Which is it
Old Sep 1, 2011 | 12:16 PM
swiftjustice44's Avatar
Universal cats can be used as long as the cat will fit. I don't know about your particular car; some late model cars have a cat built into the header pipes and a universal just won't get it. Try eBay and see if you can find an aftermarket one for cheap.
Old Sep 6, 2011 | 10:17 AM
ibanez958's Avatar
u can use a universal cat. but chances are u may need to cut & weld the OEM pipe, w/that u have 2 problems. 1) the weld & the cat. don't last very long, then u may need to replace it again later. 2) since it is not a OEM cat. the reading may be different @ the rear o2 sensor, it may still trigger the check engine light.
SadVolvoOwner
Intake, Headers and Exhaust
Apr 23, 2014 10:07 AM
JamnAuto
Nov 4, 2010 11:19 PM
imhereftw
Jan 2, 2010 09:49 PM
imhereftw
Aug 23, 2009 03:51 PM
MattB850in
Mar 21, 2007 12:52 PM
