VOLVO 850 T5 TEMP SENSOR
Old Jun 29, 2008 | 05:20 PM
andysvolvo's Avatar
Default VOLVO 850 T5 TEMP SENSOR
hello guys, quick question, can anyone point me towards the sensor that tells the radiator cooling fan to switch on?
or the sensor that tells the ecu to switch it on.
oh many thanks to tech regarding turbo guage not working i'd not connected the tube as you suggested.
this is a great site
Old Jun 29, 2008 | 05:35 PM
Default RE: VOLVO 850 T5 TEMP SENSOR
The temp sensor is in the thermostat housing. Follow the upper hose to the motor. Where it meets the motor look down on the right side. You will see the sensor sticking out of the housing. If you are going to replace it replace the thermostat at the same time. It also makes replacing the sensor easier.
AnEskimo
Mar 7, 2014 08:29 PM
blackbrick
May 7, 2011 01:46 PM
cisopen
Sep 20, 2010 05:25 PM
vcolper
Nov 1, 2006 10:20 PM
