Volvo Cassini alloys won’t fit v70
Hi friends im a new member and a convert from vag to Volvo..I have purchased some 17inch Cassini wheels but they won’t fit my v70?? My v70 hub diameter is slightly bigger that the diameter of the wheel. Was wondering if there’s any way of getting them to fit using adapters..
Older Volvos uses a 5x108 hub with 65.1 center bore, newer V70s use a 5x108 with a 63.4 center bore. Its a whole lot easier to put the 65.1 center bore rims on a newer Volvo since all you need to buy is a 63.4 to 65.1 hub centering ring. Going the other way would require an adaptor plate which would mess with offset and probably be expensive. You didn't mention which year V70 you have, but it you are trying to put new rims with the small center bore on an older car, best solution is to sell them and buy ones that fit. If you have a newer V70 with the smaller hub, you can easily find the hub centering rings on Ebay/Amazon etc.
