Volvo xc90 2006 memory
Old Oct 12, 2020 | 12:20 AM
Cindel Hobman-Cash's Avatar
Default Volvo xc90 2006 memory
Hey guys I have a volvo xc90 06 and while it was at the mechanics getting a leak fixed among other things the battery died and it was replaced, once I got my car back the gear didn't shift out of park I was told it lost its memory amoung other electronic functions which are showing no communication low signal and also no signal my question is how do I reset the memory for the gear box can I disconnect the battery and then reconnect to retrain the memory if that makes sense. New to the volvo bought it 5 months ago and have had such a headache with it please help me
Old Oct 12, 2020 | 07:51 AM
Sorry for your troubles and will be glad to help - but I'm having a hard time understanding what's wrong with your car. "Lost it's memory" does not happen when you change a battery. (well you do lose your auto up function on the front windows that simply needs to be reset)
Is your problem you can't get the car out of park? If so how are you driving the car? On some cars the shift **** will get pulled up slightly, and prevent the shifter from moving normally out of park. Try wacking the shift **** with the palm of your hand to see if it pushes down. (if getting the shifter out of park is your problem)
Old May 9, 2022 | 11:11 AM
Minmin123's Avatar
I read you need to disconnect neg. 1st then pos. 2nd, go turn the key to II position then connect pos. then connect neg. It is supposed to save memory and go back to normal.
raye321
Jul 19, 2019 08:52 PM
turbo matt
Feb 26, 2019 02:11 PM
Louise45
Jul 8, 2018 07:51 PM
bbensten
Jun 30, 2014 12:44 PM
bethanybreeze
Oct 30, 2006 12:58 PM
