wheel/tire combo
Old Aug 31, 2008 | 10:27 AM
MTSHANK's Avatar
Default wheel/tire combo
Will 2003-2004 17" turbo wheel/tire combo fit on my natural aspired 2001 V70, with any problems?
I currently am running the 15" stock wheel/tire combo.
I found a set of wheels with new tires for $500.
I would imagine I'll be ok, but just thought I would ask.
Old Sep 1, 2008 | 10:30 AM
jks2's Avatar
Default RE: wheel/tire combo
As long as both are the same # of lugs and spacing, generally 5 x 108, and the offsets are similar there should be no problem. You may get some rubbing on full lock turns though.
Old Sep 1, 2008 | 10:44 AM
MTSHANK's Avatar
aren't these basically the same car with different engine/different tire combo.
Is the suspension any different?
Old Sep 1, 2008 | 10:46 AM
The suspension will be the same. You will get slight tire rub at full lock. The minor rubbing is very common on the cars with the 17's.
Old Sep 1, 2008 | 10:48 AM
MTSHANK's Avatar
they will only rub like parallel parking then......
Old Sep 1, 2008 | 10:49 AM
Or turning hard to get into a spot or making a u-turn.
Old Sep 1, 2008 | 10:51 AM
MTSHANK's Avatar
great.......this should also help with performance in the corners as well.
My wife drives the V70, so she will prob never hear/see the rubbing.
235/45/17 is the standard size, right?
Old Sep 1, 2008 | 10:57 AM
I believe it is the standard size.
Old Sep 1, 2008 | 11:07 AM
MTSHANK's Avatar
thx...I'm sure they will improve the handling and the looks as well.........
I found tire rack has a nice tool as well for viewing tires and wheels on any vehicle as well.
Thanks for the help.
Old Sep 1, 2008 | 11:24 AM
If you buy them post before and after pics.
98T5
Dec 22, 2011 10:50 PM
jv89
Nov 4, 2011 06:45 PM
argon
May 1, 2008 08:30 PM
Capo Cam
Feb 1, 2008 06:11 PM
jc740T
Apr 5, 2005 08:37 PM
