Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
Glove compartment question
Old Jul 5, 2008 | 01:48 PM
Tractors4u's Avatar
Default Glove compartment question
I need to get behind the glove compartment. How do you get the glove compartment door to release and drop down further?
Old Jul 5, 2008 | 02:31 PM
01_fast_ride's Avatar
Default RE: Glove compartment question
This is a copy/paste. I don't have experience removing it myself. So hopefully this is adequate.
Remove the soundproofing panel on the passenger side.
The back of the soundproofing panel is secured to the dashboard with clips and sits in a groove at the front.
-Remove the two screws
-Pull the clips straight down
-Pull the soundproofing panel backwards into the car
-Lift out the soundproofing panel.
Open the glove compartment.
Slide the two hooks on each side past the tabs.
Remove the gas strut by pulling it straight out.
Remove:
-ten screws
-the connector for the glove compartment lighting
-the connector for the foot well lighting
-the glove compartment.
Chris Field
Nov 16, 2010 07:21 AM
huzzsaba
Apr 13, 2009 09:41 AM
mauriciogalvao
Nov 28, 2008 06:12 PM
elkgrove07
Apr 29, 2008 09:49 PM
robretpd
Jan 26, 2008 02:11 PM
