2002 V70 wagon fuel pump
Old Jul 10, 2020 | 07:19 AM
j&w2002V70's Avatar
Default 2002 V70 wagon fuel pump
Hi all, Have been trying to figure is it the relay or fuel pump! First which one is the fuel pump relay? Have gotten different info about its location. If is not the relay then I must test the fuel pump and hoe do you do that?
Old Jul 10, 2020 | 01:29 PM
Originally Posted by j&w2002V70
Hi all, Have been trying to figure is it the relay or fuel pump! First which one is the fuel pump relay? Have gotten different info about its location. If is not the relay then I must test the fuel pump and how do you do that?
The fuel pump relay is in the CEM under the dash, marked 2/23 on the diagram. Most of the relays are the same so just swap (same part number) relays if you think it is bad. Fuel pump fuse is #33 in the c fusebox (on the left end of the dash) Relay is mounted in the number 12 position on the CEM. A blue wire goes from the CEM to the connector under the rr seat - you can check for power to the pump there (to be sure, check while the engine is cranking) I would check power first since the CEM is not in the easiest spot to get to.
Old Jul 10, 2020 | 03:18 PM
j&w2002V70's Avatar
Thanks hoonk! I was told by some one else that the relay was there but not to look under the dash that there was a door there. But will now look under dash!!
mrskibone
Dec 13, 2011 05:58 PM
spidersilva
Aug 17, 2011 07:23 PM
biagia
Feb 10, 2010 08:13 AM
hessam69
Dec 7, 2008 09:29 PM
moonraker
May 6, 2007 03:26 PM
