fuel pump relay
Old May 6, 2007 | 10:31 AM
moonraker's Avatar
Default fuel pump relay
Hi
The famous 103 fuel pump relay, is it possible to "hot wire" the contacts on the socket partwhen the relay is removed from the base socket just to see if the fuel pump will start running.
If you see what I mean
Cheers Steve
Old May 6, 2007 | 03:26 PM
RedTurbo850's Avatar
Default RE: fuel pump relay
Yes you can solder the contacts.
http://www.matthewsvolvosite.com/cha...?p=32573#32573
spidersilva
Aug 17, 2011 07:23 PM
montysano
Sep 9, 2008 11:52 AM
madhatter
Dec 7, 2005 06:00 PM
crazypixie
Jan 22, 2005 01:01 AM
