2007 XC90 Airbag Light -Seat position sensor issues
Old Feb 25, 2023 | 08:34 AM
holm0299's Avatar
Default 2007 XC90 Airbag Light -Seat position sensor issues
Hello, first time poster here and I'm hoping someone can help. I've got a 2007 XC90 with an airbag light on and fault codes 2F02 and 2F05 : 'seat position sensor signal low' I've replaced the sensor and cleared codes and it comes back immediately. This led me to the CEM. I removed the CEM and found s little corrosion (pic attached) which I cleaned off. Some corrosion in the fuses as well. I cleaned and replaced all the fuses.
I have had some water intrusion through the A-pillar moonroof drain which I fixed.
Any thoughts here? do you think the CEM is toast even though it appears to be okay? I'm thinking that since both driver and passenger seat sensors are giving faults that it points to a central issue.
Thanks!
Old Feb 25, 2023 | 04:53 PM
holm0299's Avatar
**update** After pulling the carpet up, I was able to access the main wiring harness for the passenger cabin. There was a short in the wire leading to the seat position sensor. Cut, soldered and all good!
Dash8
Aug 9, 2022 02:47 PM
eFlick
Aug 30, 2020 07:07 PM
Paulwolf01
Jul 10, 2019 12:04 AM
nyc1836
May 16, 2017 10:58 PM
nptXC90T6
Feb 22, 2012 07:15 AM
