86 240 high nitrous oxide emissions stinky exhaust
Old Oct 19, 2006 | 03:58 PM
volvo5's Avatar
Default 86 240 high nitrous oxide emissions stinky exhaust
I have an '86 240. approx 200,000 miles, runs ok, could be better but lots of power. has failed emissions test in the oxides of nitrogen dept. Also has bad exhaust smell like burning paint. Usually able to fix most things but cannot figure this one. Gone to 3 mechanics one says air mass unit needs replacing (hope not) other says cat converter. another says adjustment. Can't afford more mechanics or dealership diagnosis. Can I establish if o2 sesor ok by disconnecting? What are reasonable steps to diagnose. I have already established fuel pressure ok to factory spec. new plugs,cap, wires, etc. timing fine, air filter fine, no vaccuum leaks, injectors fine. I would value any feedback. Thanks
Old Oct 21, 2006 | 12:33 PM
Default RE: 86 240 high nitrous oxide emissions stinky exhaust
You can monitor the O2 sensor with a digital Volt meter.
Connect one lead(positive) to the single wire on the o2. The Black lead to ground and see what ot does.
it should sweep from o to .10 I believe it is. Depending on the meter it might show and look like 0-1 volt.
If it seems to stay on the high side then it is running rich. If it seems to be low then it is running lean.
Unplug the Mass Flow sensor and see if it runs better if it deos then the Mass Flow is bad.
Hiitzsavannah
Feb 21, 2012 11:58 PM
eclund1
Jul 13, 2010 09:57 PM
timwu12
Dec 3, 2009 06:26 PM
usawebx
Sep 2, 2008 06:11 PM
laroccajohnr
Nov 29, 2006 09:25 PM
