Battery draining overnight
Old Mar 23, 2021 | 05:39 AM
Terry Anderson's Avatar
Default Battery draining overnight
Hi I’m Terry, new in here, looking for some help with a problem with my Volvo C30.
the battery is draining overnight, two nights in a row after charging, & there is a clicking sound coming from the area of the fusebox in the the passenger footwell. The battery drops so low that the car does absolutely nothing, dead as a dodo.
Any help would’ve appreciated.
Old Mar 23, 2021 | 11:05 AM
there's some info on the board and web on how to find a parasitic current draw. To start, you'll need a multi-meter. Disconnect the battery and then measure the current between the terminal and cable. I'd expect something in the 25mA range give or take. To drain a battery overnight, I'm betting you'd see 100mA or more. With that done, start pulling fuses and relays, if you see the mAs drop to a normal level, you have the circuit that's causing the problem so next step is to determine what's on that circuit.
Quite often its something simple like a glovebox light or vanity light that's not turning off - or a stuck relay that's staying energized.
Old Mar 23, 2021 | 11:55 AM
Thank you very much for your advice, much appreciated, I will do that tomorrow.
timer00
Dec 23, 2010 09:03 PM
NCdad
Dec 9, 2010 08:23 PM
jdbs3
Nov 4, 2009 02:10 PM
harebearva
Oct 18, 2008 05:11 PM
banks358
Apr 9, 2008 09:21 PM
