c70 drivers seat
Old May 6, 2007 | 04:46 PM
ehowardal's Avatar
Default c70 drivers seat
2000 C70 convertible - drivers seat won't fold forward when you pull up the lever on the side of the seat. All electronics work, but won't fold forward. Is this mechanical or an electonic switch. I found two small plastic circular turquise colored contacts about 1/8" in diameter that look like they pop intosmall holes, but don't know if these arerelated or not.I have the seat out and have opened the upholstery at the bottom so I cansee inside the back.The wire appears to be connected to the lever, but I can't see whatthe wireconnects to toward the bottom of the seat.
Any suggestions are welcome.
Old May 6, 2007 | 09:47 PM
Default RE: c70 drivers seat
The cable goes from a single connection at the handle to a double connection to the latches on each side. I bet one side is broke.
It is a pretty common problem on these seats.
Please post quiestions like these in the C70 section for more people to look at.
This way it doesn't get overlooked.
Old May 6, 2007 | 11:42 PM
ehowardal's Avatar
Yes - I found the cable and it connects to both sides - Is this something I can fix or a shop will need to do it?
Thanks, EH
Bobec
May 21, 2014 11:35 AM
rodgere
Aug 10, 2007 05:08 PM
tmixdorf
Jul 23, 2007 09:47 PM
chapin
Apr 25, 2007 03:42 PM
AAER
Apr 16, 2007 12:52 PM
