Clutch change
Old Aug 8, 2019 | 05:18 AM
Arach's Avatar
Question Clutch change
Hi all, I am new at this, I have a C70 2006 done 78K its time to change the clutch, any idea what sort of money? also the timing belt? many thanks
Arach
Old Aug 8, 2019 | 02:23 PM
timing belt is 10 years/120K miles so if you are on the original timing belt, you need to swap out the belt, idler, tensioner. Reinstall includes dealing with the VVT gear(s) which adds another 30 min shop time. I'd budget $600-700 for the timing belt job. As to the clutch, my guess is $1000 parts plus $600-800 labor. Any symptoms as to why you need a new clutch at 78K miles? If there are any signs of oil leakage, this is a good time to do the cam seals/main seal with the timing belt and the rear main with the clutch. Also consider refreshing the oil separator/PCV plumbing if made accessible when the tranny is dropped...
Old Aug 9, 2019 | 09:38 AM
Arach's Avatar
Arrow
Wow, thank you very much for the information, very informative.
Arach
Orchidcrazy
Nov 15, 2014 10:36 PM
dpriola
Apr 3, 2011 06:13 PM
BerniniCaCO3
Dec 27, 2010 07:27 PM
ibified
Sep 24, 2010 05:00 AM
Sofar.
Apr 18, 2010 10:36 PM
