Hi. New here and need help
Old Jul 30, 2015 | 11:41 AM
Debbie 1's Avatar
Default Hi. New here and need help
I have a 2000 Volvo wagon, v70 se, and it was making a cracking type sound every time I would turn my wheel... Well now the other day it really made it loud!! And since then my wheel is shaking a lot and oddest thing is I no longer have the cracking sound...I do approx 100 miles per day and am scared to drive it.
Old Jul 31, 2015 | 07:07 PM
difflock54's Avatar
If it is occurring when you have the steering on full lock or close to, it is quite likely to be a failing CV joint. (constant velocity joint)
They are located directly behind the front wheel hub assemblies and are the outer drive shaft connections designed to pivot when you steer the vehicle.
They have a rubber boot over them to prevent ingress of water / dirt etc which is very detrimental to them. You may notice them on inspection being torn already if the relevant joint is failing.
They can go for quite a period before total failure but you would be wise to have them checked out and replaced if the cause? ASAP.
Old Aug 2, 2015 | 02:02 PM
pkrface's Avatar
+1 on a likely CV joint, and based on current description of issue I would suspect you are very near total failure and when that happens you will be sitting along side the road or worse. Get it looked at before driving any distance.
Old Aug 7, 2015 | 03:32 AM
shanewilsonjr's Avatar
Welcome & Thank you all on sharing valuable information !
JimZB
Mar 10, 2014 05:58 PM
xboxuser
Apr 20, 2012 06:27 AM
kendogg
Feb 7, 2010 03:08 AM
crunch5868
Feb 29, 2008 11:19 AM
