Jolting
Old Jun 21, 2018 | 03:38 PM
Trevor Butler's Avatar
Default Jolting
Hi people
first post here,just wondering if someone can help.
Getting the jolt from drive and reverse when hot,I’ve had the oil changed,adaptions done,updates and valve body replaced with a new one but it still does the jolting,any ideas please as no hair left now.
Done 73000
volvo xc70 2012 d5 auto
Old Jun 22, 2018 | 12:01 AM
by oil change are you referring to the transmission fluid? Did your shop also inspect the motor and transmission mounts?
Old Jun 22, 2018 | 01:29 AM
Default Jolting
Hi
yes it was the gearbox oil and it will start after a stop and when I release the brake it starts the jolting before I even get to the gas and only when warmed up.
I will get all mounts checked out as well .
many thanks.
Old Jun 22, 2018 | 07:56 AM
Welcome to VF Trevor
You might also check the half shaft joints to see if one has excessive play.
Old Jun 28, 2018 | 08:38 AM
tony1963's Avatar
The valve body is typically not the issue, it is the solenoids. Have those been changed?
t18tds@gmail.com
2001-2013 model year V70
May 1, 2022 12:23 PM
Yesnosorry@hotmail.co.uk
Aug 28, 2018 05:06 PM
rjonny13
Jun 8, 2009 05:35 AM
rmprice
Nov 10, 2007 08:53 AM
peterpervy
Oct 25, 2007 12:54 AM
