Need firing order and possibly an opinion
Old Dec 22, 2023 | 07:50 PM
2006 s60 Dave's Avatar
Default Need firing order and possibly an opinion
Need firing order diagram with cylinder numbers for my 2006 S60 2.5t. Started missing and check engine light came on auto part store scanned with code reader and they said number 3 cylinder. So I'm assuming coil pack or spark plug?
Old Dec 23, 2023 | 09:40 AM
Cylinders are number 1-5. #1 is closest to the timing belt.
If you have a miss-fire - (and you have no way to check compression) After you have verified the spark plugs are not causing the problem (pull, inspect, when were they replaced last?) Swap coils with a working cylinder to see if the miss-fire moves. Then if it does can you isolate the coil as being the problem. (before buying parts you may not need)
91-740Turbo
Mar 9, 2014 04:01 AM
snowboss
Feb 3, 2012 07:08 AM
alvix89
Jul 7, 2010 12:46 PM
notny41
Feb 28, 2007 08:58 PM
connexion2005
Feb 3, 2007 08:54 PM
