s80 Strut clunk
Check your upper spring seat. You do this by opening the hood and locating the nut on the top of the strut.
Get a 13/16 wrench and try turning the nut. If it turns easy then the spring seat is bad. If it feels rubbery then it is good.
I can confirm this. I used this method on the s60 I was buying after noticing some "thunking" when going over bumps. The dealer said "no problem, I'll take care of it". It ended up being about $285 to have the work done, but he did replace the spring seat.
