Transmission Performance Low
Old May 22, 2021 | 02:42 PM
Nardus Stephan Buys's Avatar
Default Transmission Performance Low
Dear members,
After owning my beloved S40 2.0 Powershift 2012 a few years it seems she is starting with little things now. Recently (actually just after getting her serviced) the engine light stays on and then Transmission Performance Low and the engine cuts out. I then pull over switch the car off and on again and then the car drives again.
Needless to say this is an inconvenience and I am not enjoying my car like I should!
Does anyone have advice?
Old May 22, 2021 | 02:56 PM
What codes are stored in the ECM/TCM/rest of the modules? You can view a code history timeline with VIDA - what does it show? That would be a good first step.
Old Aug 28, 2022 | 02:31 AM
Alex_23's Avatar
Default Transmission performance low
Hi my car does the exact same thing just want to hear what the solution was I have an s40 2.0d 6 speed automatic 2009 model
Old Aug 28, 2022 | 05:33 PM
if you are getting a check engine light as the OP was - the next step is the same: Have the car scanned for fault codes.
Old Aug 28, 2022 | 10:00 PM
Alex_23's Avatar
Morning did have it checked out no fault codes only service over due on the motor going to service today and change the transmission oil also was even driving with the diagnostic tool plugged in no fault codes
Old Aug 29, 2022 | 08:48 AM
keep in mind not all scanners read all code sets and proprietary codes - this is where a shop with VIDA-DICE is a leg up. Good idea to have the fluid changed and confirm the level.
Old Aug 29, 2022 | 10:47 AM
Alex_23's Avatar
Okay thanks then there's another problem the engine sometimes just cuts out while driving in very low speeds then i have to start it again makes so 3 to 4 times while im driving any recommendations I saw on another thread the same problem and they also said it could be gearbox related but for.me it's almost like it's sucking air somehow like the maf sensor but I can't seem to.locate it then I'm looking for the indicator fuse and the manual doesn't give information to where it is
Tanz
Nov 6, 2019 10:06 AM
Waltonsivania@gmail.com
Sep 25, 2016 11:30 PM
2012s60t5
Jun 6, 2015 02:16 PM
Graham Scott
Jul 19, 2012 10:56 AM
tanjung66
Mar 11, 2008 12:16 PM
