View Poll Results: P0300 random/multiple engine misfire
Please help!
0%
How do i go about it? Is the spraying pattern normal?
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Trouble with random & multiple engine misfire code P0300
Old Jul 26, 2020 | 12:31 PM
Dafiawatene's Avatar
Default Trouble with random & multiple engine misfire code P0300
P0300 random/multiple engine misfire code
i have a 2001 v70 about 300,000 kilometres on it.
the engine keeps misfiring and pull the code p0300.
it a non-turbo
i have changed the following
plug coils
fuel pump
map & maf sensors
o2 sensor bank 1 sensor 1
air filter
spark plugs
engine temp sensor
fuel nozzles
throttle body and had the cylinder removed to clean the valves and have the same code.
so recently i removed all nozzles together with the fuel ray from the intake manifold leaving it exposed and crank the engine.
at initial crank, all nozzles sprayed and with continuous cranking, only nozzle 2,4 & 5 sprayed.
Old Jul 26, 2020 | 12:50 PM
check the wire harness to the injectors for any cracked connectors, you should be able to use a test lamp to see if the injector is getting a pulse. Also see if you can find a service that will clean the injectors (or see if you can find an ultrasonic cleaner). What happens if you swap position of the nozzles?
Old Jul 26, 2020 | 12:53 PM
Thanks. Nozzles 4 & 5 were swapped with 1&3, still the same result.
Old Jul 26, 2020 | 03:55 PM
so if your injectors don't fire in the same positions after the swap, then that tells me they are not getting a signal from the ECU. Sounds like a wiring or connector issue to me. You may want to try pulling out the ECU, cleaning the connectors to the ECU with some electronics cleaner then checking for continuity to the injector connections. Are there any check engine fault codes? I'd think that an open circuit to the injector would throw a code. After that, I'd check for fuel pressure at the rail and finally check compression.
jessebowen107
Oct 7, 2017 02:28 PM
Yak-Daddy
May 26, 2016 08:24 PM
sstoynov
Oct 16, 2014 03:57 PM
rudebold
Jun 17, 2013 06:14 AM
Svtfiveoh
Dec 9, 2007 09:15 PM
